problems with 1st gen b16 in 2g integra
Old Apr 29, 2002 | 11:32 AM
djay86's Avatar
Default problems with 1st gen b16 in 2g integra
The following is a problem a friend of mine wanted me to post to see if anyone here could help.. any responses are appreciated..thanks
1991 integra, i/h/e..first gen b16a from jdm1.com
car feels sluggish some times and appears to not even have enough torque to chirp 2nd, car will just lose juice for no reason while driving, like if you stop and try to go it will raise in rpm but then bog out and the motor will cut off
and then you try to start it at first it will turn over for a sec and then die again
after about a min it will start back up though...
Old Apr 29, 2002 | 12:14 PM
Katman's Avatar
Default Re: problems with 1st gen b16 in 2g integra (djay86)
ok...lets go through the basics...
Have you checked ignition & cam sprocket timing (TDC)??
Are you getting any check engine lights at all?
Have you done a compression check on the block?
Is your clutch new, fairly new, used, or old?
Old Apr 29, 2002 | 01:41 PM
djay86's Avatar
Default Re: problems with 1st gen b16 in 2g integra (Katman)
engine hasnt been touched since getting it from jdm1.com
Old Apr 29, 2002 | 01:43 PM
Katman's Avatar
uhh..maybe you should take the initiative and basically tune your engine. I get the impression you don't work on your own car, for some reason.
Old Apr 29, 2002 | 06:56 PM
riceboy's Avatar
werd
Old Apr 29, 2002 | 09:17 PM
Gump's Avatar
do a tune up!
spark plugs
spark plug wires
cap and rotor
oil change
check your timing
and also throw some fuel injection cleaner in, and clean out the intake manifold, it might be really dirty
[Modified by Gump, 10:18 PM 4/29/2002]
ShreqBoi
Jan 30, 2010 11:43 PM
PhillyB16
Oct 23, 2007 11:13 AM
djay86
Apr 22, 2002 06:46 PM
