Cracked spark plug - Heat range too hot?
Old Sep 10, 2006 | 05:40 PM
EMod Civic's Avatar
Default Cracked spark plug - Heat range too hot?
I wanted to get some opinions on the root cause of a broken spark plug problem I had today. Here is a pic of the plug:
Background info about the motor:
This plug was in my 86 Civic EP autocross car. The motor is a built up D15a3 12 valve 1.5. The motor is around 12:1 compression with a large cam, head work, etc.
The plugs were NGK BPR6EIX-11 iridium. '6' is the standard heat range for these motors.
I was running an autocross with two drivers, and we were running about every 6-7 minutes. The coruse was right at the top of 2nd gear, so we were bouncing off the rev limiter quite a bit. When the plug let go, I was trying to hold the motor right under the limiter. It hit the limiter (8600rpm), I lifted a little and held the speed, slowed a little for a turn, then got back into it and it sounded like a lawnmower, and obviously had at least on cylinder dead.
Luckly, it looks like the plug only cracked on the outside, so nothing bad fell into the chamber.
Has anyone ever seen a plug do this? Is it just a function of the plug being too hot for the motor? Any recommendation for a cooler plug? I can't seem to find one just like this in a '7' heat range. Is one heat range enough of a change, or should I go to an '8'? Any help would be appreciated.
Thanks - Chris (#11 EP)
Old Sep 10, 2006 | 05:48 PM
NJIN BUILDR's Avatar
Default Re: Cracked spark plug - Heat range too hot? (EMod Civic)
It was cracked at or prior to instalation.The vibration of the rev limiter finished it off.
ravinaziankid
Aug 14, 2012 05:25 PM
Shft@9GSR
Oct 16, 2003 12:04 PM
Mefain
Jun 3, 2003 10:15 AM
Vadian
Dec 3, 2002 04:11 PM
