STILL HAVING THE SAME PROBLEM CAN'T REVV PAST 3K
ok i changed the dizzy and it still can't revv past 3k i reset the ecu and does the same thing. and i was wondering can the ecu be wrong? because it still gives me the codes 4 and 14. and like i said i changed the dizzy with a reman from autozone and it still has the same problem. its giving me a headache can someone help me out please! thank you.
if the wiring is correct then its either your dizzy or ecu...im still leaning towards the wiring though...i was having the same problem on my the other day and i had the wires for the CKP in the wrong locations on the ecu connector...just something to think about
