ecu troubles
Old Sep 6, 2009 | 11:58 AM
Tylerjdmgsr's Avatar
Default ecu troubles
so i recently chipped my ecu and it was fine then i took off the plastic and pushed the wiring in a little so the plastic would be firm and the check engine light came and the idle was at 2 and a half then when i loosen the wiring and take off the plastic it stops? do you know what this is from?
Old Sep 6, 2009 | 12:13 PM
sixfourkiller's Avatar
Default Re: ecu troubles
its so basic what u wrote maybe if u had a bit more detail on what ecu and model year u was working on.. and a bit more detail on what u did might help someone to help u with your problem
lsjon
Engine Management and Tuning
May 30, 2008 08:41 AM
sirhavok
May 30, 2007 06:45 PM
LoooseGSR
Feb 16, 2004 11:41 AM
