o2 sensor question
i tried searching.... i have jdm b16 swap(obd1) p30ecu in my 96 civic ex(obd2a)...and i have dc sport headers.....the o2 sensor plug wont reach from the plug to the o2 sensor hole on the header....has anyone else have this problem..and wats the best solution to fix that..thanks honda tech!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 »</TD></TR><TR><TD CLASS="quote">did you buy the dc header new? if so, it should have came with a wire extender.
huh? When did they start doing that? Mine didn't...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super_nguyen »</TD></TR><TR><TD CLASS="quote">
just a quick question, what do i do with that brown tube? im not sure if its anti seize, since the stuff i use is normally silver.</TD></TR></TABLE>
I believe it is anti-seize.
</TD></TR></TABLE>huh? When did they start doing that? Mine didn't...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeedLessInc »</TD></TR><TR><TD CLASS="quote">you can buy a o2 extender from holley for $30.</TD></TR></TABLE>
or buy one from rywire, the link i gave, for $20.
X2 mine came with one
</TD></TR></TABLE>X2 mine came with one
if you buy a b series header it prolly wont come with an extender, as the factory manifold already locates the o2 sensor at the same place as the dc header. it will prolly only come with an extender if you buy a d series header. if your engine came with a manifold and an 02 in it use that one as it should already be long enough.
bam69icp
Oct 21, 2008 08:35 PM
efking1985
Feb 12, 2007 08:31 AM
