fuel pump won't prime randomly, once started no problems
Old Sep 10, 2006 | 09:59 AM
deckster333's Avatar
Default fuel pump won't prime randomly, once started no problems
I have a strange problem. (92 Civic) Sometimes when starting the fuel pump won't prime, therefore not start. Resetting the ecu has worked a few times. Today I inspected the Main relay and put it back in, looked fine. Tried like 10 times, still no prime. Then all the sudden its priming. This problem occurs every few weeks. Anyone help?
Old Sep 10, 2006 | 10:27 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: fuel pump won't prime randomly, once started no problems (deckster333)
check the pins on the ecu and on the mfr. Also check the harness that it plugs into. If that fails check the wire to the fuel pump. Also check the fuse for the fuel pump. Even thou they look good they can be bad. Check the fuses scoket for corrision and make sure its tight
Old Sep 10, 2006 | 10:43 AM
mdr191's Avatar
yeah man, i had a 89 crx and ocassionally at random times did I have the same problem you had, if you turn the ignition and none of your lights on your cluster light up, and you cannot hear your fuel pump once you place the car in the run position, then its prolly the main relay..........when the main relays start to go bad, you can inconsistantly start the vehicle on certain days. eventually the main relay will totally give out and you wont be able to start it at all........that's the best advice i could give you man, same thing happened to one of my other cars.........later!!!
91GEDHATCH
Sep 30, 2011 02:53 AM
stkinge
Nov 21, 2009 08:38 AM
teknohatchie91
Apr 15, 2009 11:40 AM
Siegfried
Aug 21, 2006 11:17 AM
92DXinMIAMI
Jun 8, 2005 06:43 PM
