Filling up gas.
Just recently every time I go to the gas station after I put gas in the car and start it again the car bogs. The RPM's will drop to like 200-300 and the car barely stays on. Thefirst time it happend I wasn't expecting it and the car actually turned off. Now When I get gas I just tap the gas pedal to shoot the rpms up and then the car idles correctly. Its a b16a swap in a 2000 hatch with stock fuel work. Any ideas?
You only gave it 1/2-hour, what do you expect?
Does it only happen after opening/closing the fuel tank?
Or does it happen anytime you try to restart the car when it is warm?
There isn't much to go with here...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyCooter »</TD></TR><TR><TD CLASS="quote">
There isn't much to go with here...</TD></TR></TABLE>
Sounds like it's either pump related, or pressure related.
I have had the same problem. Try unplugging your TPS sensor and see if it does it anymore. I unplugged my and it stopped. Then i replaced it 3 times and problem persists. Dont know after that. I just keep mine unplugged and it runs great but i have my check engine light on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyCooter »</TD></TR><TR><TD CLASS="quote">You only gave it 1/2-hour, what do you expect?
Sorry man just a little antzie...anyway
yes only after I open and close the tank but i never tried it without
putting in the gas. I'll try opening it then closing it and see what happens. The fuel pump is like a year old and i bought it brand new.
Ic Ic well im not hurting the car in any way then right? I guess i'll try cleaning my fuel filter and checking my fuel pressure. Thanks for the tips.
