Bent Valve?
So I just bought a new crx. It has a b16 swap in it. When it idles you can hear some sort of valve noise. Like a small clanking sound. Is there anyway to tell if its a bent valve or if it just needs to be adjusted? Also if it is bent how bad is it to drive on it?
If its pretty quiet keep in mind that it could also be normal honda valve train tapping , they arent very quiet you know. It could also just be your injectors tapping , also normal quiet sounds.
