Spark plug re-thread kit
Old Sep 10, 2006 | 04:51 AM
Clairvoyant's Avatar
Default Spark plug re-thread kit
I'm looking to get a spark plug re-thread kit for one plug hole on my civic engine. Some of you may have seen my other post about the stuck spark plug. Anyways, I got the plug out. I think I'll re-thread the hole as there is some damage near the bottom. Is there a certain kit that might be the best? Also is it a 14mm or 16mm kit that I would need? I have a D15B7 engine (I know it's not a powerful engine, but it's damn good mileage). I don't have my tools or spark plugs with me right now, so just wanted to ask about what width they are. Thanks.
Old Sep 10, 2006 | 10:35 AM
Default Re: Spark plug re-thread kit (Clairvoyant)
Anyone know what size?
Old Sep 10, 2006 | 04:28 PM
It's been pretty lonely here all day....
Old Sep 11, 2006 | 10:10 AM
Anyone at all???? Is it a 14mm kit or not?
Old Sep 11, 2006 | 10:12 AM
Archidictus's Avatar
Unceasing Measure
If you take a stock spark plug to SEARS or any hardware store that sells tools, you'll be able to test different taps and dies until you find EXACTLY what you need. Rather than sit here doing nothing waiting for someone to hold your hand, just go to the store with a plug in-hand and make it happen, dude.
Also, I sure hope you're not planning on tapping that hole with the head still on the block...
Old Sep 11, 2006 | 10:20 AM
WhiteOnRice's Avatar
Default Re: Spark plug re-thread kit (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Also, I sure hope you're not planning on tapping that hole with the head still on the block...</TD></TR></TABLE>
Yeah, metal shavings are not an engine's friend.
Old Sep 11, 2006 | 10:28 AM
instructor74's Avatar
Default Re: Spark plug re-thread kit (fizix_skate)
It can be done with relative safety. Apply a heave grease to the tap and slowly work it down the hole back it out several times clean the threads reapply the grease. continue this until all the threads are re-tapped. It is not the preferred method but if done right no metal will get into the cylinder
Old Sep 11, 2006 | 11:30 AM
SkoundrelUSA's Avatar
cute little bastard
I'm pretty sure the thread size is 12mm X 1.25. Get yourself a Helicoil kit from like NAPA or something. I did this for my tranny bolts and it worked great. Only thing is, I don't know how you're gonna get into the spark plugs holes with a tap since its so deep...
Old Sep 11, 2006 | 11:46 AM
Unceasing Measure
Default Re: Spark plug re-thread kit (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure the thread size is 12mm X 1.25. Get yourself a Helicoil kit from like NAPA or something. I did this for my tranny bolts and it worked great. Only thing is, I don't know how you're gonna get into the spark plugs holes with a tap since its so deep...</TD></TR></TABLE>
He'll have to take the head off and do it from the bottom.
Old Sep 11, 2006 | 01:35 PM
Froth's Avatar
Default Re: Spark plug re-thread kit (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">It can be done with relative safety. Apply a heave grease to the tap and slowly work it down the hole back it out several times clean the threads reapply the grease. continue this until all the threads are re-tapped. It is not the preferred method but if done right no metal will get into the cylinder </TD></TR></TABLE>
Theres an expensive diffrence between relative saftey and absoloute saftey. I'd rather take the time to do it right and be sure than to do it half-assed and ruin a perfectly good engine.
ravinaziankid
Aug 14, 2012 05:25 PM
arielb1
Jul 24, 2004 10:24 AM
princeallure
Jul 12, 2004 07:33 PM
Mefain
Jun 3, 2003 10:15 AM
