JDM cluster
ok so i bought a jdm cluster and I was told by 1 of my friends that I have to have a certain electronical piece for the speedometer to work? is this right or can i just plug it right in??
there is a little red search button at the top. use it, it is your friend.
but since you ask, you need a electronic vss from a jdm b16 i believe. and wire the sensor one ground, one power and one signal which you wire to the ecu so vtec works and then on the the cluster. you need to mod the plugs and repin according to some thing on here. just search. its your project and im not searcing for you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart »</TD></TR><TR><TD CLASS="quote">A stock VSS outa a DC-5 ITR works great, Thats what I'm using. </TD></TR></TABLE>
srsly. Da man knows his ****!
thats a mabe on that vss cause i have abother guy wants to give me his also but all my connections to the back of the cluster will be fine right? but thankx every1
Daniel_san
Apr 26, 2004 09:22 AM
