stray plug needs id
Hmm, a little help here. I'm in the process of swapping a '97 JDM B18C into my '00 Civic, utilizing a '00 5spd Civic EX harness. Now I thought I had all the clips accounted for, and the ones that I don't need as well, but here I am with one more. Can any one help me id this plug? It was getting dark out when I noticed it...
It's square, Grn/Blk and Yel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">thats definitely not O2 sensor, it looks like a plug off an automatic transmission or reverse sensor plug (I see that it's plugged it)</TD></TR></TABLE>
Yeah I didn't think it was either but I didn't wanna say anything b/c I'm not 100% sure on that and I didn't want 50 people to be like "ahh you ******* moron" because I'm sure there's some gay difference like that between USDM and JDM engines :-P
I was thinking reverse plug, but it doesn't look like it would reach with the EX so I mean why would it not fit here, y'know?
Anyways, at OP:
Was the harness off of a manual or auto EX (I don't know much about automatic trannies, so I can't attest to what that other dude said, but it may be an extra plug)? Also, did u label all ur plugs & count 'em before u pulled the motor?
Anyways, at OP:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TorquelessB16 »</TD></TR><TR><TD CLASS="quote">Isn't that the O2 plug I see already plugged in directly underneath the coolant hose attaching to the motor?
Maybe vtec solenoid. Just a guess. </TD></TR></TABLE>
Yeah, VTEC, not the O2, that's the other side of the engine :-P
Ok, it's not VTEC since the solenoid is already plugged in (1 wire plug).
It's not the VTEC oil pressure switch because the JDM motor doesn't have it and I already wrapped and set that plug from the harness aside.
It's not O2 because a) it's only 2 wires (EX has 4 wires per O2 - heated), b) the primary O2 is on the other side, at bottom of header (EX harness again).
It can't be something from an auto harness because its a 5spd harness. The reverse switch is just to the right and is plugged into the 2 wires I extended from the cabin for reverse (auto->5spd conversion). The reverse switch wiring from the tranny is Grn/Grn and square for anyone wondering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Anyways, at OP:
Was the harness off of a manual or auto EX (I don't know much about automatic trannies, so I can't attest to what that other dude said, but it may be an extra plug)? Also, did u label all ur plugs & count 'em before u pulled the motor?</TD></TR></TABLE>
It's a 5spd harness as stated. I made sure to be as thorough as possible comparing plugs from motor to motor but my original D16 was mated to an auto, so I didn't use that harness. I had another one from a 5spd so I used that.
I'm going to go check it over again now that it's light out... I was pretty sure I had everything accounted for. Will report back if I find anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. »</TD></TR><TR><TD CLASS="quote">its the reverse light sensor.
/thread.</TD></TR></TABLE>
Just to make sure, the 5spd harness has the reverse plug on it? I'm assuming it's connected to the A clip at the ECU side which is then routed elsewhere.
Hmm, ok, I guess that's possible then, since I was going by the auto-5spd swap guides that say to route the wire out to the reverse light sensor off the tranny. I guess that was so the harness wouldn't have to be swapped.
woob87
Engine Management and Tuning
Mar 30, 2018 09:09 PM
rysingsun86
Mar 28, 2007 09:29 AM
