People that took out A/C in 96-00 Civic or never had A/C-Need help
Old Sep 9, 2006 | 09:45 PM
DFW's Avatar
DFW
Default People that took out A/C in 96-00 Civic or never had A/C-Need help
Can anyone with a 96-00 CX/DX hatch (coupe too i think) post your OEM block off plate that goes in place of the a/c condenser or know the part # to it?
Old Sep 9, 2006 | 09:58 PM
speedjunky01's Avatar
Default Re: People that took out A/C in 96-00 Civic or never had A/C-Need help (DFW)
I just left it open, there was a block off plate? wtf?
Old Sep 9, 2006 | 10:02 PM
DFW's Avatar
DFW
Default Re: People that took out A/C in 96-00 Civic or never had A/C-Need help (speedjunky01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedjunky01 &raquo;</TD></TR><TR><TD CLASS="quote">I just left it open, there was a block off plate? wtf?</TD></TR></TABLE>
That's what I was told https://honda-tech.com/zerothread?id=1700581
I've never seen one myself.
Old Sep 9, 2006 | 10:14 PM
I couldnt find it.
here look around this site.
https://www.hondapartsdeals.co...onent=
Old Sep 9, 2006 | 10:16 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedjunky01 &raquo;</TD></TR><TR><TD CLASS="quote">I couldnt find it.
https://www.hondapartsdeals.co...onent=</TD></TR></TABLE>
I tried on http://www.hondaautomotiveparts.com/ too and couldn't find it. I might just make something maybe if I can't find an OEM on, if there ever was.
Old Sep 9, 2006 | 10:18 PM
why do you even want one? why not just paint a pice of metal flat black and stick it infront on the frill?
I dont see what the block off plate ie helping at all.
Old Sep 9, 2006 | 10:22 PM
DFW's Avatar
DFW
Just personal prefrence, don't like the gap there.
Old Sep 9, 2006 | 11:31 PM
JICEK9's Avatar
it DOES serve a purpose. do you think honda puts it on there for looks. air passes through the grill and into the radiator. but if there is a huge hole next to the radiator, the air is going to go through that because there is less restriction. by installing the plate, you force the air to pass through the radiator.
and to the poster, why don't you just call your local honda dealer and ask them for what your looking for? they should stock it because it's an accident item.
Old Sep 9, 2006 | 11:38 PM
Eran's Avatar
HT White Ops
Heel Toe Auto sells them.
http://www.heeltoeauto.com/Hon....html
Old Sep 9, 2006 | 11:43 PM
JICEK9's Avatar
Default Re: (Eran)
/\/\/\/\/\thats not what he's looking for it's just a sqare peice of plastic.
Old Sep 9, 2006 | 11:44 PM
DFW's Avatar
DFW
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">it DOES serve a purpose. do you think honda puts it on there for looks. air passes through the grill and into the radiator. but if there is a huge hole next to the radiator, the air is going to go through that because there is less restriction. by installing the plate, you force the air to pass through the radiator.
and to the poster, why don't you just call your local honda dealer and ask them for what your looking for? they should stock it because it's an accident item. </TD></TR></TABLE>
Sweet now I know it serves a purpose
I'll call them Monday.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Heel Toe Auto sells them.
http://www.heeltoeauto.com/Hon....html</TD></TR></TABLE>
I thought it would look different, like a big plastic square? Hum..
Old Sep 9, 2006 | 11:58 PM
JICEK9's Avatar
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">I thought it would look different, like a big plastic square? Hum..</TD></TR></TABLE>
yes it will. thats not the right part
Old Sep 10, 2006 | 12:03 AM
DFW's Avatar
DFW
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">yes it will. thats not the right part </TD></TR></TABLE>
Yeah, on I guess he thought I was talking about the piece in the dash.
Do you know the exact name for it? Air conditioning block off plate?
Old Sep 10, 2006 | 12:09 AM
IM ALL BOB's Avatar
Default Re: (JICEK9)
Here is the part you are looking for, wish I knew the Part number
Its called a Condensor Cover. you can find it under
the area of "Front Fender" good luck. This is used
if without a A/c system or Full length Radiator. Air always looks for the lest restrictive way to flow, and thus a large portion of air will flow around the radiator.
but usually you wont see any overheating problems unless you live in a very hot climate area. or you are on track (Road Course)
Old Sep 10, 2006 | 12:10 AM
DFW's Avatar
DFW
Default Re: (IM ALL BOB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IM ALL BOB &raquo;</TD></TR><TR><TD CLASS="quote">Here is the part you are looking for, wish I knew the Part number
but usually you wont see any overheating problems unless you live in a very hot climate area. or you are on track (Road Course)</TD></TR></TABLE>
Which site did you find that on? And thanks a lot!
I give Honda a call Monda then
Old Sep 10, 2006 | 12:16 AM
IM ALL BOB's Avatar
Default Re: (DFW)
Well I found that on http://www.hondaautomotiveparts.com... I also checked it out on
SLHONDAPARTS.COM... i used this Part # 74149-SR3-000 and it came up
with the same part.. So that may be the part# for it.
These are the best sites for looking up OEM parts
Old Sep 10, 2006 | 12:26 AM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IM ALL BOB &raquo;</TD></TR><TR><TD CLASS="quote">Well I found that on http://www.hondaautomotiveparts.com... I also checked it out on
These are the best sites for looking up OEM parts </TD></TR></TABLE>
I checked on there and couldn't find it at all haha.
Thanks.
Old Sep 10, 2006 | 04:11 AM
JSPECSIR's Avatar
Default Re: (DFW)
took about 15 sec. to find. he told you exactly where its at.
just click on buy at the end of the line.
http://www.hondaautomotivepart...ENDER
Old Sep 10, 2006 | 08:24 AM
Eran's Avatar
HT White Ops
Oh, you guys are talking about the shield in the bay .... my bad.
Old Sep 10, 2006 | 08:45 AM
gottalovethe4door's Avatar
to the top, cause i didnt know it may hinder performance.... thnx
Old Sep 10, 2006 | 09:11 AM
DFW's Avatar
DFW
Default Re: (gottalovethe4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR &raquo;</TD></TR><TR><TD CLASS="quote">took about 15 sec. to find. he told you exactly where its at.
http://www.hondaautomotivepart...ENDER</TD></TR></TABLE>
Before he told...
Old Sep 10, 2006 | 09:25 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gottalovethe4door &raquo;</TD></TR><TR><TD CLASS="quote">to the top, cause i didnt know it may hinder performance.... thnx</TD></TR></TABLE>
apparently nobody did especially for all the shiity info that was floating around this thread. I'm glad I clicked on this thread and was able to help
Old Sep 10, 2006 | 09:26 AM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">apparently nobody did especially for all the shiity info that was floating around this thread. I'm glad I clicked on this thread and was able to help </TD></TR></TABLE>
Yeah thanks a lot and IM ALL BOB
Kimade
Jan 31, 2014 06:07 PM
6SPD_EK
16
Jan 16, 2007 01:20 PM
Eran
Nov 26, 2006 07:37 PM
CivHatchH22
Jun 5, 2003 11:41 AM
