Which Motor Mounts for turbo??
Well, I've heard when getting motor mount inserts you only need one set of either the Energy Suspension set including: Front Lower Left Torque Mount, Front Lower Right (tranny) Torque Mount, Rear Firewall Mount.
Or the Prothane ones that include: Upper Left Mount and Upper Right Mount
Which ones do I need, or do you guys recommend replacing the OEM mounts all together for something else? I really don't want anything too harsh, since this is a daily driver, but I don't mind a little vibration. Inputs???
I have the energy suspension set installed on my em1 and they are ok.I cant complain but they are nothing to brag about.They worked ok with my drag kit but with my built motor and newetup i am gonna go hasport
I bought an NRG engine torque damper and it eliminated 90% of my wheel hop. My car used to hop the **** out of itself until I installed the torque damper. Now it's pretty hard to make it hop at all. I feel no extra interior vibrations compared to before. $55 well spent.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cluelessmale »</TD></TR><TR><TD CLASS="quote">window weld all of them</TD></TR></TABLE>
thats what i did...you notice every rattle and squeak at idle now...but wheel hop is non-existant
Bump because I ordered both, but they sent me the wrong Energy Suspension kit, they sent me trailer arm bushings....
But I did get the correct Prothane ones.
Will I be okay with just the prothane inserts? Because I heard that you really only need one of the two posted above, I just don't which one I need.
But I did get the correct Prothane ones. Will I be okay with just the prothane inserts? Because I heard that you really only need one of the two posted above, I just don't which one I need.
i run the tq mount inserts and a rear mount insert, rest of my mounts are 100% OEM.
Im gonna get a tq damper tho- i got one but it didint fit the swap it was for the stock sohc :-/
onyx00
Sep 24, 2004 01:00 PM
SOHC_Brian
Aug 11, 2004 11:30 AM
Brewer
Mar 23, 2004 07:30 PM
