H22A4 with ATTS into Ek, need axle help
Old Sep 9, 2006 | 05:57 PM
kasso's Avatar
Default H22A4 with ATTS into Ek, need axle help
Hi, I want to swap an H22A4 from a 99 Prelude SH into my 96 civic hatch. I've been searching for about two days now and I need to know who makes the custom axles for EK with the atts unit (female joint). I've heard of this being done before and I would rather buy these axles (hopefully stage 2 or 3), than getting a machine shop to do this for me. In the worst case scenario, i would just get the custom bracket for the midshaft and base tranny; but i'd like to avoid that. i could careless about the atts not working and being dead weight. also, do I need custom mounts to drop this motor in with the atts unit (as opposed to regular H swap mounts)?
Old Sep 9, 2006 | 07:11 PM
v4lu3s's Avatar
RTFM
a custom axle shop is where i would go. I suspect that fact that the ATTS not working being 90lbs of dead weight has kept a lot of people from seeing a point of stocking performance axles for a swap like that.
Old Sep 10, 2006 | 06:10 AM
kasso's Avatar
what about the regular swap mounts? do they work with atts?
Old Sep 10, 2006 | 02:04 PM
kasso's Avatar
bump
Old Sep 12, 2006 | 05:35 PM
kasso's Avatar
Has anyone ever got the atts to work with a stock prelude ecu in a civic? also, the two hoses coming off the unit, is the for power steering fluid or for tranny fluid?
btw, would h2b work with the h22a4 (no bolt for midshaft)? i got a gsr tranny with no plans for it.
Old Sep 12, 2006 | 05:42 PM
v4lu3s's Avatar
RTFM
the h2b halfshaft mount is not deigned to mount on the ATTS equipped block so that would need to be customed.
Old Sep 12, 2006 | 05:44 PM
kasso's Avatar
would it work with the base h22? which midshaft, b series or h series?
Old Sep 13, 2006 | 06:18 AM
v4lu3s's Avatar
RTFM
as far as i know it uses a b series midshaft and a custom plate to mount to the base model h22 block.
Old Sep 13, 2006 | 11:42 AM
YZFR6's Avatar
Default Re: H22A4 with ATTS into Ek, need axle help (kasso)
Are you planning on keeping the ATTS or you have that block with a 5 speed trans to it?
Old Sep 21, 2006 | 09:59 PM
kasso's Avatar
i want to get rid of the atts and the tranny for it and run a regular 5 spd tranny.
thats my dx
Oct 25, 2012 07:44 AM
abs0Lut
Oct 20, 2011 06:54 AM
stockb18c
Feb 16, 2009 12:31 AM
jdmlove
Apr 30, 2006 10:43 AM
BOOST_92
Apr 27, 2006 02:58 PM
