CHECK ENGINE LIGHT ON BUT NO CODE.......
Old Sep 9, 2006 | 02:57 PM
kaoss_11's Avatar
B A N N E D
Default CHECK ENGINE LIGHT ON BUT NO CODE.......
I was throwing 3 codes and I fixed them all. The three were map sensor, tps sensor, and the iat sensor. Once they were all fixed the the check engine light came on 2 minutes later. I disconnected my battery and disconneted my ecu. So when I go to check my codes with the wire it doesnt flash or anything. The check engine light just stays. Any help appreciated I searched and no info related to my issue motor is a obd 1 h22 running crome.
Old Sep 9, 2006 | 03:03 PM
EK k kay's Avatar
Default Re: CHECK ENGINE LIGHT ON BUT NO CODE....... (kaoss_11)
Solid cel usually means bad ecu or bad map on the chip.
Old Sep 9, 2006 | 04:02 PM
kaoss_11's Avatar
B A N N E D
Default Re: CHECK ENGINE LIGHT ON BUT NO CODE....... (EK k kay)
ok thanks
Old Sep 9, 2006 | 05:05 PM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">Solid cel usually means bad ecu or bad map on the chip.</TD></TR></TABLE>
solid CEL when the jumper is jumped means no codes.
check your backup/radio fuse to make sure it's not blown.
Chris
Old Sep 9, 2006 | 05:41 PM
kaoss_11's Avatar
B A N N E D
will do
Old Sep 9, 2006 | 09:01 PM
EK k kay's Avatar
Default Re: CHECK ENGINE LIGHT ON BUT NO CODE....... (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">
Chris</TD></TR></TABLE>
A bad ecu/chip will cause a solid cel whether jumped or not.
Old Sep 10, 2006 | 12:03 AM
kaoss_11's Avatar
B A N N E D
thanks
b16jaf
Nov 26, 2007 07:15 AM
kaoss_11
Sep 10, 2006 04:14 PM
Civicse
17
Mar 8, 2005 05:39 PM
SkunkCrxSi
Jul 29, 2004 11:31 PM
