car wont rev past 5500 got cel code 6 &7 help
Old Sep 8, 2006 | 10:57 PM
xfrankx's Avatar
Default car wont rev past 5500 got cel code 6 &7 help
ok so i checked the codes it was throwing and its a 6 & 7.
six is coolant temp sensor
seven is tps
my question is will the tps not being calibrated cause it to not rev past 5500?
also my car is running rich but im sure its from the coolant temp sensor thats not a big deal to me ill fix that but i really wanna know what would cause it to not rev where it should.
its a b18b in a eg and turbo.
the tune is the same it always was everything is the same on the car until this happened.
any ideas on the revving problem?
Old Sep 9, 2006 | 02:30 AM
92ehatch's Avatar
Default Re: car wont rev past 5500 got cel code 6 &7 help (xfrankx)
pretty sure the tps code will cause it to not rev all the way.
i would gaurantee one of the two codes is causing it anyways. get em fixed and find out
Old Sep 9, 2006 | 07:26 AM
Kod Sol's Avatar
Default Re: car wont rev past 5500 got cel code 6 &7 help (93cb7sedan)
I have the same problem in my 90 integra. It won't rev past 5500, its like it bogs out, and my check engine light goes on every once in a while. Do you think it would be the same problem or just an old motor?
Old Sep 9, 2006 | 08:17 AM
xfrankx's Avatar
Default Re: car wont rev past 5500 got cel code 6 &7 help (Kod Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kod Sol &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem in my 90 integra. It won't rev past 5500, its like it bogs out, and my check engine light goes on every once in a while. Do you think it would be the same problem or just an old motor? </TD></TR></TABLE>
check the code that its throwing and go from there. could be alot of things.
im gonna calibrate the tps and see what happens
Old Sep 9, 2006 | 11:22 AM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xfrankx &raquo;</TD></TR><TR><TD CLASS="quote">
im gonna calibrate the tps and see what happens</TD></TR></TABLE>
yeah,TPS code will cause limp home mode.check it via the manual procedure.
Chris
Old Sep 11, 2006 | 10:55 AM
ek_chris's Avatar
any tips on how to calibrate the tps? I know you have to use a multimeter and .4V is 0% throttle and 4.5V is WOT.. but getting those damn leads into the wires is impossible.
I guess im gona have to call my tuner to grab his laptop and his crome..
Old Sep 11, 2006 | 11:03 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (ek_chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_chris &raquo;</TD></TR><TR><TD CLASS="quote">any tips on how to calibrate the tps? I know you have to use a multimeter and .4V is 0% throttle and 4.5V is WOT.. but getting those damn leads into the wires is impossible.
I guess im gona have to call my tuner to grab his laptop and his crome..</TD></TR></TABLE>
Search for it. There are threads on TPS calibration. If you can't probe the wire, strip it, duh.
And none of those CEL's will cause your car to run rich.
I also assume you have a chipped P28, otherwise your boy with Crome isn't going to be able to do anything for you...
Old Sep 11, 2006 | 11:23 AM
fmrprojects's Avatar
Default Re: (JDM_Ej)
if you are throwing a code then the ecu will go into limp mode and not let you redline. to calibrate the tps, just use a needle and stick it in the middle wire. put the red/pos lead on the middle wire and the black/neg lead on a good ground. then adjust the tps to .5V
Old Sep 11, 2006 | 01:43 PM
xfrankx's Avatar
Default Re: (fmrprojects)
i fixed the temp sensor but i didnt calibrate the tps yet.
im gonna do that later. it sucks not being able to rev past 5500
Granny_shifter
18
Sep 17, 2012 08:08 AM
99Em1Daniel
10
Dec 4, 2010 01:27 PM
kirbyman
11
Jan 16, 2008 03:07 PM
EckoTech
Sep 30, 2005 08:43 PM
Blaze45
32
Jun 28, 2003 09:35 AM
