burning oil... but have good compression
Old Apr 29, 2002 | 05:44 AM
neumonik's Avatar
Default burning oil... but have good compression
I've been noticing that my car has been burning quit a bit of oil. If I get on the throttle I see blue smoke bellowing out the back and then when I let off black smoke pours out.
I checked the compression and everything is within spec. The timing is in spec. The engine was sitting for about 14 months though. Anyone have any suggestions as to what might be causing this?
Thanks for any help.
- Frank
-- edit --
I forgot to add that my vtec doesn't work until 7200rpm. Someone at work thought maybe that could be causing this. Does that sound resonable?
[Modified by neumonik, 9:50 AM 4/29/2002]
Old Apr 29, 2002 | 09:31 AM
88_SC_CRX_Si's Avatar
New User
Default Re: burning oil... but have good compression (neumonik)
Have your PCV checked out. Sorta sounds like it may be hung up, from it setting for awhile... hehehe
Old Apr 29, 2002 | 10:06 AM
neumonik's Avatar
Default Re: burning oil... but have good compression (88_SC_CRX_Si)
pcv == postive crankcase ventalation right? The black canister on the back of the block.
Thanks for the help.
Old Apr 29, 2002 | 10:12 AM
Kataku2K3's Avatar
The valve guides may be leaking too.
Old Apr 29, 2002 | 10:14 AM
neumonik's Avatar
Default Re: burning oil... but have good compression (JDMspecEG6)
is there any easy way to check for that? Leakdown test?
benji7288
20
May 29, 2009 08:16 AM
AndrewHuffman
Sep 18, 2008 06:17 PM
climb_on
Aug 4, 2007 07:14 PM
kornerk12
May 1, 2007 12:09 AM
oneslowcivic
10
Nov 11, 2003 03:27 PM
