Need a good Crome tuner in Seattle or surrounding area
I need you to tune out my idle. It surges from 1100-1500. It does it continually then stops for a while then comes back and stops.
^Might do that tomorrow. Hoping it isn't going to cost me a full 1hr rate. C-Speed is too far for me. If it's something normal then I don't really want to mess with it trying to get it fixed.
I don't think it's a vacuum leak because it only happens sometimes. I used a boost leak tester through my intake manifold and there were no leaks. It may be a bad sensor, but I wouldn't know which one.
I've cleaned and replaced that thing.
I've had the problem ever since I converted to obd1. With obd2 and my stock ecu it doesn't do it at all. I'm throwing no cels either. I'm running Crome on a chipped p28 with dsm 450's.
i got the same issues and also run crome. i just learned to live with it..its really annoying sometimes at lights and ive also replaced all my sensors.
edit: (we got the same whp but im NA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">Yeah those b20 bottom ends are nice. A buddy of mine has one of them with a ls head. His low end and throttle response kicks my ***.</TD></TR></TABLE>
Damn right *evil grin*.Im also on crome and i took off the backup fuse(7.5a)put it back on and let the car run with no accesories until the fan kicked on twice.The surging went away and i hope it never comes back
JD95hatch
14
Sep 5, 2004 07:20 PM
