No power to the center console.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Like Hondas »</TD></TR><TR><TD CLASS="quote">Is it a fuse?</TD></TR></TABLE>
That's a hard question. It could be a fuse. It could also be a battery that's disconnected. Could be a broken battery cable. Could be many things. Hard to say for sure if it's a fuse or not. You could start by checking the fuses.
Check the Fuses in the under hood fuse box, most Honda/Acuras use a 7.5A fuse for the stock HUs constant lead, it may not be enough current for the aftermarket HU, DONOT replace with bigger fuse if that's the problem, run a fused line from the batt. to the aftermarket HUs constant power lead, don't forget to "cap off" the stock constant lead.
94
94
Lude@Heart
Sep 22, 2005 01:51 AM
