what the hell is the differance?
ok i have a jdm b16 and i wanted to change the pistons to ctr, but people are saying running thse pistons will yeild crazy compression ratios, but i have a compression calculator and it doesnt nearly come close to what people are saying. they say run itr pistons, but what i dont understand is that if the jdm ctr angine itself has a 10:8:1 compression and the itr has a 11:0:1 compression, why would the ctr pistons yeild higher than the itr pistons?
Modified by kantfadedisazn at 7:29 PM 9/7/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Inspired ED7 »</TD></TR><TR><TD CLASS="quote">I've heard they jump to about mid 11 cr, who knows...</TD></TR></TABLE>
yeah but why would the ctr be better than the itr if the stock engines allone dot yeild that cp ratio?
Internals... Crank bla bla are different size.. Even a gsr with a b16,gsr, type r etc... head would change the cr of the motor **** idk! lol bump!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Inspired ED7 »</TD></TR><TR><TD CLASS="quote">Internals... Crank bla bla are different size.. Even a gsr with a b16,gsr, type r etc... head would change the cr of the motor **** idk! lol bump!
i know right very confusing thats why i really want to find out so i dont put the wrong thing in and have a crazy high compression and blow my engine by using pump gas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kantfadedisazn »</TD></TR><TR><TD CLASS="quote">
i know right very confusing thats why i really want to find out so i dont put the wrong thing in and have a crazy high compression and blow my engine by using pump gas.</TD></TR></TABLE>
You build it take it to get tuned
just did the compression calculator from zealautowerks and this is what the results were http://www.zealautowerks.com/
Block-B16A
81-Bore (mm)
77.40-Stroke (mm)
203.25-Deck Height (mm)
Head-B16A
42.70-Combustion Chamber Volume (cc)
Piston-PCT (JDM B16B)
8.63-Dome (cc)
30.73-Comp Height (mm)
Connecting Rod-B16A
134.00-Rod Length (mm)
Headgasket Thickness-OEM 3-layer
0.02600000-Thickness (in)
0.00-Bore diff (mm) *
Maxium Operating RPM-8000
Elevation-fl which is 100ft
Results
Static Comp Ratio-11.91: 1
Effective Comp Ratio-11.89: 1
Displacement-1595.55cc
Rod / Stroke Ratio-1.73
Piston-to-Deck Height-(-0.007)
Mean Piston Speed-1713fps
Max Piston Acceleration-114842fps2
Block-B16A
81-Bore (mm)
77.40-Stroke (mm)
Head-B16A
8.63-Dome (cc)
Connecting Rod-B16A
Results
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kantfadedisazn »</TD></TR><TR><TD CLASS="quote">just did the compression calculator from zealautowerks and this is what the results were http://www.zealautowerks.com/
Block-B16A
81-Bore (mm)
77.40-Stroke (mm)
Head-B16A
8.63-Dome (cc)
Connecting Rod-B16A
Results
does that sound right
Block-B16A
81-Bore (mm)
77.40-Stroke (mm)
Head-B16A
8.63-Dome (cc)
Connecting Rod-B16A
Results
because the ctr is a 1.6 and the itr is 1.8 a smaller engine producing almost 200 hp needs the high comp as in the itr its almost the same thers really no diffrence the ctr pistons in my book are better
aris04
Jun 7, 2004 12:03 PM
duRritztiNy
35
May 16, 2003 10:36 PM
