CRX Hesitation/ Code 14 IAC
Old Sep 7, 2006 | 12:34 PM
HBK's Avatar
HBK
Default CRX Hesitation/ Code 14 IAC
My cars been running like its out of gas at low rpms, and I just threw a IAC code 14 last night. It stutters real bad and its driving me nuts. I recently replaced my IAC valve because my idle was horrible and it worked for a couple weeks, and now its just stuttering.
Any ideas? I havent had the chance to take off my IAC again, but if its not that anything else?
Old Sep 7, 2006 | 04:08 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: CRX Hesitation/ Code 14 IAC (HBK)
Did you get a new IACV? If not, check if it's clean (the valve will be white inside), and if it's not, clean it with carb cleaner. If it's new, it may just be bad or your wiring could be bad. Follow the check procedure in your repair manual (if you don't have one get one ).
InvaderTrax
Jul 4, 2007 02:55 PM
Dc_Ek
Dec 8, 2005 03:37 PM
ko
May 22, 2005 10:54 PM
Behan
Dec 25, 2003 03:51 AM
JSpecwest
Dec 27, 2001 10:54 AM
