Noobiest question ever
Old Sep 7, 2006 | 11:04 AM
paulab's Avatar
Default Noobiest question ever
My passenger side headlight burned out, I bought the replacement bulb, popped the hood and twisted (attempted to, anyway) the back piece to remove the old bulb. Well, I tried and tried and was only able to get the thing to twist a tiny bit. The back piece comes off, however, the bulb is stuck in there. I will try spraying some WD-40 to loosen it but before I do I want to make I am not doing something incredibly dumb and that it is just stuck. So that's my noobiest question ever, am I doing something incredibly dumb (other than posting this for all to see? )
Old Sep 7, 2006 | 11:14 AM
Jagan'92's Avatar
Default Re: Noobiest question ever (paulab)
so you basically unplugged it, or removed the rubber cap, and can't get the plastic ring bit off? those things are a pain to get off, at least the 4th gen.
Old Sep 7, 2006 | 11:29 AM
paulab's Avatar
Default Re: Noobiest question ever (Jagan'92)
No, I can unplug it but can't get the actual bulb out from the headlight casing
Old Sep 7, 2006 | 11:53 AM
pizzamanprelude's Avatar
there is a wire clip that holds the bulb in, push it in the sort off prise it left or right ( i cant remember) that'll let the lamp out
Old Sep 7, 2006 | 12:26 PM
paulab's Avatar
Default Re: Noobiest question ever (pizzamanprelude)
Thanks, I'll check that when I leave the office
JDM Approved
Oct 20, 2008 03:59 PM
sittingonROTAS
Nov 1, 2005 05:04 PM
Dino_D
10
Dec 25, 2003 11:16 AM
TruBlu
Jan 27, 2003 05:12 PM
Akshay
May 8, 2002 11:22 AM
