Whoom whoom whoom....WTF?!?!?!
When ever I am rolling,
the wheels make this sound; whoom whoom whoom whoom.
WTF?! People have told me to rotate tires, check the brakes, etc.
Could it be axles, un-balanced wheels, streering rack, a bearing,
what? It's driving me nuts knowing my car is'nt 100% healthy.
Please shoot me some advice. I know someone's delt with this before.
Car is '93 si hatch/95 US GSR heart.
All help/advice is much appreciated.
Thanks for looking!
Thanks for looking!
Tires are damn near brand new.
When i'm rolling down the street, whoom whoom whoom is what you hear
coming from the front suspension area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8killa91 »</TD></TR><TR><TD CLASS="quote">that happend to my booy it was hit camber was so bad so long it messed up his bearrings. </TD></TR></TABLE>
wheel bearings?
wheel bearings?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgcrx »</TD></TR><TR><TD CLASS="quote">wheel bearings?</TD></TR></TABLE>
Yes.
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">do the wheel bearings need to be hydraulicly pressed in and out?</TD></TR></TABLE>
Ya
Probably need a new hub too. Should come in under $200 for everything.
If you want to make sure it's the wheel bearing, jack up the car and try to wobble the wheel.
Ya
Wheel bearing, about 70 a side, or you could just source a new hub assembly. I got another hub fro 40 from a junk yard as opposed to 70 for the bearing and another 20 to get it pressed in and out.
Thanks too all who responded. Your help is greatly appreciated.
When I turn either direction, the steering wheel shakes a bit and
the noise gets louder.
Gotta get back to watching season two of Lost on dvd.
I never would have guessed you listen to ICP, what a joke. Speak english.
OP, like stated, most likely your bearings.
wheel bearings. Grab a front wheel, and shake it back and forth, to and from you. If you feel play like something's loose, its your wheel bearing. Like someone else said, do all 4. cause once one goes bad, the others follow.
I had this same problem shortly after I swapped motor.. forgot to tighten the axel nuts :-x.. wouldnt hurt to check them
Hope this helps in some way shape or form
-Cody
-Cody
///Nick
Mar 9, 2012 11:43 AM
aznromeo4u
Jun 28, 2010 07:08 AM
ekcivic9
Oct 15, 2005 01:49 PM
