motor shuts off after complete warm up
Old Sep 7, 2006 | 09:18 AM
the jdmchop's Avatar
Default motor shuts off after complete warm up
k guys ive been having a problem with the car ilding low wen coming to a stop after warm up. i had the alt tested and it was bad so replaced with a know good one
still same problem so i think it might be a intake leak, nothing
is there a way to reset the IAC?
gonna check if thsi alt is also good or not
and after it is warm sitting at idle it just shuts off it doesnt stumble or anything just shuts off and will start right back up?
Old Sep 7, 2006 | 09:21 AM
Miracle's Avatar
Default Re: motor shuts off after complete warm up (The Chemical Dust Project)
Sounds like either the IACV or an ignition module. Put a miltimeter on the IACV and see if it is within specs. I will see if I can some up with those specs.
Any CEL at all?
Old Sep 7, 2006 | 09:27 AM
Default Re: motor shuts off after complete warm up (.Red.EM2)
no cel
Old Sep 7, 2006 | 09:29 AM
Miracle's Avatar
I would check that IACV to be honest man. That would be my first thing. Second, like I said, would be the ignition module. What year car and engine is it?
Put a miltimeter on the IACV and check it's resistance. Compare that to the numbers in a Haynes manual.
Old Sep 7, 2006 | 09:30 AM
i have experienced the bad dizzy and it would have to cool down to start back up this will start right back up
ima take the iac off and try to clean it or check it out
i think it may be the iac
Old Sep 8, 2006 | 10:44 AM
Default Re: motor shuts off after complete warm up (Danny Alves)
iac and fiv are good
Old Sep 8, 2006 | 10:55 AM
junior40er's Avatar
make sure you ICV isn't wired backwards. It should close up completly when warm. If wired backwards it will also be backwards. iono maybe im wrong but its worth a try.
Old Sep 8, 2006 | 11:01 AM
Default Re: motor shuts off after complete warm up (junior40er)
the iac always sucks in air to keep a idle
the fast idle valve stops sucking when it gets hot
they are both owrking properly
Old Sep 8, 2006 | 11:04 AM
2to5coupe
Guest
Posts: n/a
what about main relay?
Old Sep 8, 2006 | 11:12 AM
Default Re: motor shuts off after complete warm up (2to5coupe)
wen the motor dies the vafc stays on along with the ecu so i dont think its the main relay
ive switched pumps also and still no dice
Old Sep 8, 2006 | 12:10 PM
Miracle's Avatar
Default Re: motor shuts off after complete warm up (brian rolls on hub-caps)
My last idea, the ignition module, as stated previously.
Don't know of anything else to tell you other than that.
92 CIVIC HATCH VX
Dec 25, 2015 06:01 PM
CRX_nut
11
Jan 21, 2010 10:32 AM
ProjectEvilEj2
Jun 4, 2009 08:46 AM
stopspazinout
20
Sep 27, 2008 06:16 PM
y0whuddupb
Feb 14, 2006 05:45 PM
