Aynone know of a way to replace the plastic straw on ebay catchcans??
Ok so long story short- i have an ebay catchcan and there is a clear straw like "level indicator" tube on the side I need to replace. Does anyone know where I can get a replacement? Would ace hardware or home depot have something like this?
Its 2 90* plastic elbows and a clear vinyl straw that goes between them:
[straw on right of can + endcaps]
what exactly are those black pieces? it looks like you could maybe just use some 90* hose fittings, some clear hose and clamps.
why does it need to be replaced anyways?
that looks like "swagelok" fittings, try industrial and hydraulic supply house, i get them for a couple bucks each and the line is .40 a foot, not totally clear though.
just take off the brass fittings and take them to your local Lowes or home depot. You can get some 90 degree nipple fittings and a tube to fit in the plumbing section.
i bought a universal can off summit a while back and made my own tube on the side from parts i bought at home depot
^ thats what I tried and it ripped the seal there was some barbed metal thing around the fitting...
Anyway went to home depot and there were a few option- they actually had the connector elbows i needed but only in plastic so i just used 90* brass 1/8" npt to MIP connections with a vinyl tube and screw clamps, ended up pretty good!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">^ thats what I tried and it ripped the seal there was some barbed metal thing around the fitting...
Anyway went to home depot and there were a few option- they actually had the connector elbows i needed but only in plastic so i just used 90* brass 1/8" npt to MIP connections with a vinyl tube and screw clamps, ended up pretty good!</TD></TR></TABLE>
pics??
pics??
d i know it looks ghetto thanks to my generous amount of jbweld
but it works-
the drawback of the ebay catchcan is the actual inlets are 3/8" and then it reduces to barely any larger than a pentip where it actually enters the can. This is no good for breathing.
I used jbweld putty to block off the 2 ports and screwholes on the top of the can. Using a 1" holesaw bit (which was actually WAAY too big) I added 3 1/2" fittings to the can, 2 for the block breathers and 1 for a larger top breather. I then added the new straw which is just 2 90* 1/8" to 1/8" MIP elbows with a piece of 3/8" vinyl tubing between, and voila! improved catchcan!
I think im gonna buy another ebay one and try to "fix" it more cleanly but for now this works :-p
but it works-the drawback of the ebay catchcan is the actual inlets are 3/8" and then it reduces to barely any larger than a pentip where it actually enters the can. This is no good for breathing.
P@@RB@Y
17
Oct 28, 2005 12:59 PM
Tad
Apr 26, 2004 01:53 PM
kikiboi
53
Oct 10, 2002 08:13 PM
