no pressure to the clutch help anyone
Old Sep 7, 2006 | 03:33 AM
macfadyen's Avatar
Default no pressure to the clutch help anyone
my del sol has very little to no pressure in my clutch and when the cars away for the night the clutch sinks to the floor it has a new clutch transmission master cylinder slave cylinder ive also bled it 3 times anyone have any ideas what i could try now
it a 1.6 delsol thanks
Old Sep 7, 2006 | 05:06 AM
1992Si's Avatar
Look for a leak under the carpet up by the top of the clutch peddle.
You must have a leak somewhere in the system.
Old Sep 7, 2006 | 06:05 AM
doublejz's Avatar
Default Re: (1992Si)
check for fluids by the clutch pedal (master cylinder) or on the front of the tranny (slave cylinder) if those look good you most likely have air in the lines.... bleed that ****. I prefer the cheap cheezy self bleeders from advanced auto parts. Makes it an easy 1 man job.
hopefully your pressure plate didnt go on you.
Old Sep 7, 2006 | 12:00 PM
macfadyen's Avatar
Default Re: no pressure to the clutch help anyone (macfadyen)
k thanks ill try re bleeding it and looking for a leak in the line
BCZEVO
Dec 2, 2016 02:29 PM
jtran21
Honda Civic (2001 - 2005)
Mar 11, 2013 08:32 PM
jaywo_23
Oct 11, 2007 08:49 PM
92CIVICCX
Sep 26, 2002 05:16 AM
solsearching
Oct 10, 2001 04:55 PM
