***** Another b20/vtec question regarding zex nos kit *****
Ok tomorrow im gonna order those RS Machine b20 itr style 84.5mm pistons.Now Im also gonna have rs machine hone and bore the block to match the pistons 84.5 mm.Now im gonna run the b20b stock sleeves.Also i wanna have like eagle rods and arp big rod bolts.My question is Will running a zex wet system at 100 shot with that compression i think is 11-8-1 be pushing it to much on that b20b block on stock sleeves but with forged pistons and rods and tuned on hondata s100.
Also which nitrious kit will be better to use and safer if not the zex wet system.
These are the pistons
These rods heagle h-beam
This is the zex wet kit
Modified by IT'S ME DAVID at 9:32 PM 9/6/2006
84.5mm stock sleeves? g'luck
edit: and correct me if i'm wrong, but aren't those pistons not forged?
my buddy ran a 100 shot single in his stock bottom b20, with a shitty tune for more than 2 years, best time being a 11.80 with open diff and small slicks, you just have to do it right
yea it will have a god tuner.i had before as in my sig a 85mm stock sleeves b20vtec making 241 whp.so i know what b20 can do.But just a little skeptical on the 100 shot.
