Misfiring B16 Problems
Old Sep 6, 2006 | 06:41 PM
SimplyTron's Avatar
Default Misfiring B16 Problems
I have a 90 CRX with B16. I had some fuel pressure problems recently, mostly my fault. I have a B&M FPR and I had it adjusted to 38 psi WITH THE VACCUME ATTACHED. I didnt know your supposed to pull the vaccume to adjust it. Well the other day I was adjusting it and the top snapped off so I put my stock FPR back on. That when I realized you have to have the vaccume off. So now the car misfires while Im reving it in neutral if I give it more than say 1/2 throttle it misfiries going up. I have a chip disabling o2 sensors and knock sensor running the stock PR3 maps. Im trying to figure out why its misfiring. Nothing was changed besides bringing the fuel pressure back to stock instead of way high. Im thinking maybe the plugs are bad but why would they work with all the fuel and not with the stock ammount of fuel? Any ideas?
Old Sep 6, 2006 | 07:14 PM
SiR Inspired ED7's Avatar
Default Re: Misfiring B16 Problems (SimplyTron)
are you sure your spark plugs were put back in the correct order?
Old Sep 6, 2006 | 09:09 PM
salman's Avatar
Try turn on the head lights, if it keeep misfiring then check ur plugs, regap them,
If u turn on the head light and the missing is gone, then its ur ELD,
Silvertc
Sep 23, 2010 09:49 AM
crxh22project
Apr 6, 2005 08:07 PM
EFSiR
Oct 20, 2003 09:07 AM
631 Teggy
Dec 17, 2002 10:04 AM
Norcalstoppy
Aug 9, 2002 10:37 AM
