Adjusting ignition timing, no need to jumper anything right?
From: I told you to wait in the truck in Texas, United States
Yes..'88 models have it under the hood and
the later models have it inside at the passenger side kick panel.
Jumping the connector let's the ECU know that the timing
is being adjusted so that it does not try to correct for the distributor
being moved..
being moved..
Also see: http://www.norcalcrx.org/ht.html#ignition
'88 model:
Later models should be in this general area:
'88 model:
Daniel
Aug 22, 2003 07:05 PM
