How to get linkages better?
Old Sep 6, 2006 | 11:33 AM
B18 CYA's Avatar
Default How to get linkages better?
Hey all, I have Hasport linkages in my civic but I have a really wierd issue. All 4 passes I did at the track on saturday, I missed 2nd. It's like it doesn't want to go into 2nd until a few tries. So I let my other friend make a run at the track with my car and he missed 2nd also. On the street, its really hard to go into 3rd.
I had other modified linkages in my car that I borrowed from a friend and they were perfect. These hasport ones I am having issues with. Is there anything that can be done to fix this issue? Perhaps modify the linkages in a way or what...
Old Sep 6, 2006 | 12:08 PM
locash's Avatar
Default Re: How to get linkages better? (B18 CYA)
If the linkage has any play in it, send it back to hasport for repair.
Old Sep 6, 2006 | 12:21 PM
DaveF's Avatar
Default Re: How to get linkages better? (locash)
those hasport linkages dont have enough room for the shifter to get it in gear... you can take a die grinder to open the hole up alittle on the front and rear side where the shifter fit through the stabilizer bar.
get a stock linkage, cut/fit........
Old Sep 6, 2006 | 04:28 PM
Mr Rex's Avatar
Default Re: How to get linkages better? (dturbocivic)
i am having a similar problem but it is with the avid racing linkage. the opening where the shifter comes up threw the floor is two big for the shifter so i had to put electrical tape around the ball on the shifter so i could get it to shift.
any one else run into troubles
champLSinteg
Mar 7, 2007 04:54 PM
Bob_760
13
Sep 18, 2006 05:44 PM
Vp Special K
Dec 4, 2003 12:21 PM
Blaze45
Aug 19, 2003 08:15 AM
