Tachometer is lagging behind actual engine speed....
Old Sep 6, 2006 | 10:43 AM
Mikey3000's Avatar
Default Tachometer is lagging behind actual engine speed....
when my motor is up around redline, the tach only reads around 4-5k rpm. my motor is running fine. no bouncy idle, no misfiring etc. i have an Apex EL II tachometer. anyone have any ideas? is there a test to see if the tach is getting a good signal? i checked the ground and it seems ok. the tach was working fine up until monday afternoon. motor is 95 H22A, car is 92 Civic HB CX.
Old Sep 6, 2006 | 02:25 PM
Boostfed's Avatar
New User
Default Re: Tachometer is lagging behind actual engine speed.... (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">when my motor is up around redline, the tach only reads around 4-5k rpm. my motor is running fine. no bouncy idle, no misfiring etc. i have an Apex EL II tachometer. anyone have any ideas? is there a test to see if the tach is getting a good signal? i checked the ground and it seems ok. the tach was working fine up until monday afternoon. motor is 95 H22A, car is 92 Civic HB CX.</TD></TR></TABLE>
By chance is there a switch or anything to switch it to 4 cylinder, 6 cyl or 8 cylinder modes? A friend of mine had a shift light in his car and one day it stopped lighting up like it was supposed to , come to find out he accidentally changed the setting on the back of the shift light to like a 8 cylinder lol
Old Sep 6, 2006 | 05:10 PM
Mikey3000's Avatar
Default Re: Tachometer is lagging behind actual engine speed.... (Boostfed.com)
no there's no switch. i just ran hookups straight to the battery and tach signal wire and its still lagging so it looks like the tach itself is messed up. there goes $230 down the drain.
Old Sep 6, 2006 | 05:36 PM
N20civicB18's Avatar
Might not be a switch, usally there is a wire loop for you to cut - read the directions!
Old Sep 6, 2006 | 05:39 PM
Boostfed's Avatar
New User
Default Re: Tachometer is lagging behind actual engine speed.... (N20civicB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">Might not be a switch, usally there is a wire loop for you to cut - read the directions!</TD></TR></TABLE>
Yeah BUT Kyle he had it working for awhile already so that is why i mentioned the switch to him
Old Sep 6, 2006 | 05:59 PM
ohh okay thats my bad Terry, I get lazy and dont read the full posts like I should.
Do you have a EX/SI cluster you could swap in to check your tach signal? OR can you datalog?
Old Sep 7, 2006 | 03:21 AM
Mikey3000's Avatar
i can datalog. i guess that's a good/simple thing to do. thanks.
Old Oct 19, 2006 | 01:46 AM
PooM's Avatar
Mine is doing the same I have the Autometer Autogage tach, I connected the revs wire to the factory tach. Its fine at low revs, between 1-2.5k, but after that it starts lagging. When I hit redline on the tach reads 7500rpm instead of 8500rpm.
I have been told to wire it straight to the dizzy to get a more accurate reading. Does anyone know which wire this is in the engine bay?
Old Oct 19, 2006 | 03:06 AM
DaveF's Avatar
Default Re: Tachometer is lagging behind actual engine speed.... (PooM)
blue.
i believe its the coil - wire
garykf16
Apr 3, 2009 10:00 PM
Eyal 951
Dec 24, 2007 09:35 PM
SleepnCiViC
14
Jan 16, 2004 05:46 PM
