how much does a melted cat affect performance
hello guys
we had a friends car on the dyno and it made **** power. we found out that the catalytic converter melted. at idle the was barely any exhaust pressure comn out (i know at idle it is low but im tokn much lower than that)
the car is idling ike it struggling to breath and its sounds like a dog
we pulled the cat off and it was completely melted.
i wanna know if anyone has come across this and how much was the performance affected.
it would depend on how bad it were melted, i would say it could easily cut your power in half if it was signifigantly melted. exuhaust wouldnt be able to escape from the cylinder, so it would create a pumping loss, as well as diluting your a/f mixture that is entering the cylinder.
thanks nate. your the second person to say that. that makes me feel so much better
we just had the cat fix on the weekend. we went with a 2.25 metal high flow.
ill keep you posted
ill keep you posted
its still idling like a dog but we hit the dyno on saturday ill let u know.
theres a few things that needs to be changed for the final dyno session.
ie. i found out that the timing wasnt set. we retarded the dizzy all the way as a precaution to stop the pinging. and the tuner was suppose to set the timing but he didnt.
itr_henrik
Feb 28, 2007 02:14 PM
