Pulling tranny
Old Sep 5, 2006 | 09:53 PM
cdmEFhatch's Avatar
Default Pulling tranny
Well, I think the clutch just went to hell in my car tonight, so how much of a pain in the *** is it to pull the tranny out of EF with a D16? I've pretty much never touched an import before so this could get ugly. What are your recommendations?
Old Sep 5, 2006 | 11:03 PM
f-it3's Avatar
Default Re: Pulling tranny (cdmEFhatch)
i dont think its hard at all just take your time and check your work
Old Sep 5, 2006 | 11:32 PM
Cheeech's Avatar
Default Re: Pulling tranny (f-it3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f-it3 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think its hard at all just take your time and check your work</TD></TR></TABLE>
Yeah, since it is your first time, do some research. You might encounter some road blocks on the way but make sure u do everything right and dont half *** it. This is your first time so it will be a good learning experience and it will most likely take u all day but its way better then paying someone to do it.
Old Sep 6, 2006 | 12:44 AM
7PSI CRX's Avatar
You might think I'm crazy....
But you will find it 1000X easier if you remove the engine & tranny together,
and install the clutch outside the vehicle.
Piece of cake!
Old Sep 6, 2006 | 06:27 PM
cdmEFhatch's Avatar
ok, so now I'm pretty sure it's the input shaft...I believe I read somewhere that it's a common problem, is this correct? Anyone have some better info about this, or hell, maybe a new tranny I could pick up for cheap?
Old Sep 6, 2006 | 06:30 PM
SiR Inspired ED7's Avatar
Don't Fawk Up.
Old Sep 8, 2006 | 12:04 PM
Tyson's Avatar
if youve not pulled the tranny before, its actually not fun and can be very tricky and time consuming. it of course gets easier the more you do it, but the first time is always a bitch.
if you need to replace your input shaft bearing too, then thats a whole extra operation of opening the tranny. just my opinion, if you had to do all this and put it back together, if everything goes well, youre still looking at a whole 2 day weekend worth of work.
Old Sep 8, 2006 | 12:08 PM
justseeingifitistaken's Avatar
Default Re: Pulling tranny (Tyson)
i have changed a clutch with the engine still in the car and with it out....in is a lot harder and takes a lot longer. take it out and be sure to replace throw out bearing and cv joint seals at the same time. that just my opinion.
Old Sep 12, 2006 | 07:47 PM
cdmEFhatch's Avatar
Default Re: Pulling tranny (hondaJDMimports)
looks like it's just gonna get a Si tranny swap to go along with the Si D16 swap it already has....sweet
Old Sep 12, 2006 | 07:50 PM
Tippyman's Avatar
I did a tranny swap by myself with no air tools in about 9 hrs. It's easier when you have experience, but it's not a terribly hard job.
Old Sep 12, 2006 | 08:00 PM
cdmEFhatch's Avatar
Default Re: (Tippyman)
sweet, I have air tools handy so that should shave off some time
Old Sep 12, 2006 | 08:06 PM
Tippyman's Avatar
Default Re: (cdmEFhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cdmEFhatch &raquo;</TD></TR><TR><TD CLASS="quote">sweet, I have air tools handy so that should shave off some time</TD></TR></TABLE>
Just get a Helms or Chiltons and go to town. Don't try it without one if it's ur 1st time. I still need to refer to mine fairly often.
Old Sep 12, 2006 | 08:11 PM
cdmEFhatch's Avatar
thanks for the tip. what do those things normally run and could one be obtained at your local Checker or Advance Auto Parts store?
Old Sep 12, 2006 | 08:14 PM
Tippyman's Avatar
my GF bought one for me at a.a. parts. They're at barnes and noble too.
Also, ball joints tend to be a common point of frustration. check my project thread, i posted a link on the 1st post for a how-to that is easy as hell.
DubyaAye
Oct 5, 2004 08:15 AM
SimbaDogg
Jul 6, 2004 07:49 AM
Yellb16crxsi
21
Dec 13, 2003 08:48 PM
94si94cx
Oct 1, 2003 10:15 AM
satan_srv
Aug 8, 2003 04:50 PM
