low idle(barely runs) giving it cause causes the engine to die
Old Sep 5, 2006 | 07:21 PM
DelsolioGSR1996's Avatar
Default low idle(barely runs) giving it gas causes the engine to die
I noticed that days prior to the problem i would get some backfire on decel usually higher rpms(aftermarket exhaust itr header open)
the day prior to the big problem I noticed acceleration is not good at all. almost like not all cylinders where firing but not sure about it.
the day after that I started it up and instantly the idle went to almost zero but it barely runs. I give it gas and it conks out pretty fast. cant get anywhere.
wiring is good for what I see. could it be injectors? iacv dirty? I have no idea what to check.
Old Sep 5, 2006 | 07:22 PM
brookliner7's Avatar
is it throwing a CEL?
Old Sep 5, 2006 | 07:34 PM
nsxmatt's Avatar
Default Re: low idle(barely runs) giving it gas causes the engine to die (DelsolioGSR1996)
Could be a number of things, almost sounds like a jumped t-belt to me but that's hard to tell without looking at the car.
Old Sep 5, 2006 | 07:45 PM
cwd14's Avatar
that sounds like what was happening when the vacuum line to my map sensor cracked
Old Sep 6, 2006 | 08:40 AM
Default Re: low idle(barely runs) giving it gas causes the engine to die (cwd14)
cell code is just long, continuous blinks (1.5 sec)
Old Sep 6, 2006 | 08:51 AM
EGwhat!!!'s Avatar
count the blinks
Old Sep 6, 2006 | 09:41 AM
cashshoes's Avatar
cell blimking continous while the car is running means the car is misfiring really bad i would say check your fuel filter. is it hard to start up the first time you start it up for the day also how you can check is take your fuel line off your fuel pressure regulator it is supposed to have pressure in it so when you take it of gas should shoot out if it dosent then it is your fuel filter
Old Sep 6, 2006 | 09:45 AM
EGwhat!!!'s Avatar
Default Re: (cashshoes)
if its a miss fire check you plugs pull them out and make sure they are making contact. do you remove or replace your plugs? if you did you could have them in the wrong order.
Old Sep 6, 2006 | 02:17 PM
its not hard to start up at all. fuel filter is brand new. didnt remove the plugs from the dizzy and the engine head is pretty easy to put back the way you found it. any other ideas? extremely low idle and passes out when gas is given
Old Sep 6, 2006 | 02:23 PM
okay its actually giving me a code now when i jump the ecu. its 3 short blinks before a long one. I thought the 10's go first then the singles. so is it a code 13? barometric sensor? would that cause the low idling and engine failure upon gas pressure? the baro sensor is inside the ecu 92 and up and that would make perfect sense that I screwed something up in there with the hondalog cable.
Modified by DelsolioGSR1996 at 6:12 PM 9/6/2006
Old Sep 6, 2006 | 03:12 PM
Jonknee's Avatar
When mine did that i had bad wiring at the throttle position sensor, and the eacv.
Old Sep 6, 2006 | 05:14 PM
Default Re: low idle(barely runs) giving it gas causes the engine to die (Capn'jazz)
when yours did what? the code or the bogging down of the engine.
Old Sep 6, 2006 | 05:34 PM
Old Sep 6, 2006 | 05:52 PM
Jonknee's Avatar
Check your map sensor/ wiring.
If the short blinks are first, its a code 3, the long one could just be the " Starting over to read codes again"
Old Sep 7, 2006 | 08:09 PM
ty will check that. well stock "untouched" p72 ecu gives the same exact result so i think we can rule out ecu trouble.
Old Sep 27, 2006 | 05:36 PM
sorry for the late update. it was the tensioner to the timing belt. they dont work to well when theyre loose lol. runs like a champ and thankfully no damage from the off timing. thanks all for your help.
92 white eg
Feb 2, 2009 07:45 PM
IntegraType-R
Aug 26, 2008 01:09 PM
JDM manc 10
18
Sep 21, 2006 12:42 PM
88turdbucket
Feb 3, 2005 04:31 AM
DSeriesBeeKilla
Nov 14, 2002 12:33 PM
