fitment of 15x7 +35 on 91 crx, any rubbing?
Old Sep 5, 2006 | 02:37 PM
easynowrudeboy's Avatar
Default fitment of 15x7 +35 on 91 crx, any rubbing?
im currently running some 15x7 +40 rotas on 205/50s on my crx dropped on stance coilovers. They came with the car and i prefer a slightly more flush fitment. im thinking about picking up some new wheels and am wondering if 15x7 +35 would rub at all if i run the same tire size (205/50s)? i like to keep the car pretty low with a slight tire tuck front on rear. thanks for any replies, im new to hondas and am not familiar with what normal flush fitment sizing is on these cars.
Old Sep 5, 2006 | 04:27 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: fitment of 15x7 +35 on 91 crx, any rubbing? (easynowrudeboy)
Assuming this is for street use, run 195/50-15 instead. It's the proper matching size for a CRX, it won't throw off the speedometer/odometer, it won't make your car accelerate slower, and it won't rub. 205/50-15 is too big.
Old Sep 5, 2006 | 04:38 PM
Default Re: fitment of 15x7 +35 on 91 crx, any rubbing? (nsxtasy)
ok thanks, but i shouldnt see any rubbing then with the 15x7 +35s along with 195/50s?
Old Sep 5, 2006 | 05:22 PM
XkjeldorX's Avatar
if u get the +35 u will definately rub. i have +38 rotas and i rub when i make a really hard turn or when there is a dip on the road and the wheel goes inside the fender. im looking for +40 rotas now.
edit: if u have 205/50 it will rub, dont know about the 195 series
Old Sep 5, 2006 | 08:06 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by easynowrudeboy &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks, but i shouldnt see any rubbing then with the 15x7 +35s along with 195/50s?</TD></TR></TABLE>
I know 195/50-15 won't rub if the wheels have the proper offset, but I'm not sure what the best offset is to avoid rubbing.
You would also be better off with 15x6 wheels than 15x7, which will make your tires look streeeeetched out on the rim.
Old Sep 5, 2006 | 08:46 PM
thanks guys helpful info
Old Sep 5, 2006 | 10:08 PM
vtecsi00's Avatar
15x6.5 with a plus 40 to 45mm offset will make it work
judgeDredd
Apr 15, 2009 04:08 PM
sikefcrx89
Nov 25, 2008 03:35 PM
bcborn
13
Jan 31, 2006 08:21 PM
bcborn
Jan 20, 2006 09:57 PM
all motor crx
Sep 28, 2002 12:21 AM
