car overheating. temp drops when heat is on.
Old Sep 5, 2006 | 01:09 PM
pearl's Avatar
Default car overheating. temp drops when heat is on.
i have a 93 ex coupe. bone stock z6 motor.
the fan doesn't come on.
both rad hoses feel hot/warm.
when i put the defroster on full blast hot, it drops down.
i've heard coolant temp relay.. any other ideas?
searched around too, but just looking for something more specific.
Old Sep 5, 2006 | 01:12 PM
philosofy1's Avatar
Default Re: car overheating. temp drops when heat is on. (pearl)
how long are you waiting to see if the fan is turning on? sounds like a bad thermo.
Old Sep 5, 2006 | 01:18 PM
Miracle's Avatar
Default Re: car overheating. temp drops when heat is on. (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a bad thermo.</TD></TR></TABLE>
What I was thinking as well.
Either that, the coolant temp sensor isnt telling the fans to kick in, or the relay isnt allowing the fans to come on.
Pull the resistance specs on the relay and the temp sensor, and make sure they are within spec. If not, there is your awnser. If they are, Im pretty sure it is your thermostat.
Old Sep 5, 2006 | 01:28 PM
pearl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">how long are you waiting to see if the fan is turning on? sounds like a bad thermo.</TD></TR></TABLE>
i had the car driving around today for a good 45 minutes, so im sure it would have kicked on by then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 &raquo;</TD></TR><TR><TD CLASS="quote">
Pull the resistance specs on the relay and the temp sensor, and make sure they are within spec. If not, there is your awnser. If they are, Im pretty sure it is your thermostat. </TD></TR></TABLE>
looks like ill replace the thermostat first. the car DOES have 221k on it
thanks for the fast responses guys.
DookieHowser
Jul 6, 2007 06:12 AM
Lanceuppercut
Sep 28, 2005 03:57 PM
ismokev8s
Dec 9, 2004 01:33 PM
EGhatched
Mar 14, 2004 04:17 PM
P1mpSlap
Jun 17, 2003 07:27 AM
