please help with my d16z6 swap in my 97 hatch
Old Sep 5, 2006 | 01:02 PM
ek4__'s Avatar
Default please help with my d16z6 swap in my 97 hatch
its been atleast three months since i swapped my d16z6 into my 97 hatch. from the start it was a challenge since, i was going from obd2a to obd1, 3 wire to 2 wire IACV, and the rewiring the dizzy. i did my research and figured most of it out. the car started up but ran slug-gish and sloppy. it would idle up and down and the check engine light would come on every now and then. i fixed what ever i could then the check engine light stop coming on and the car was running alittle better.
just today the code 9 (cyp) came on again. when it drives it feels werid as hell. its as if the timing would jump.
i got the dizzy wires all right but its as if they are not getting a strong enough signal. WHAT TO DO?
Old Sep 5, 2006 | 01:05 PM
BauleyCivic's Avatar
Risky Business
Default Re: please help with my d16z6 swap in my 97 hatch (ek4__)
What ECU are you using? What is your ignition timing set at?
Old Sep 5, 2006 | 01:10 PM
ek4__'s Avatar
Default Re: please help with my d16z6 swap in my 97 hatch (BauleyCivic)
im using the p28...and how do you check the ignition timing? if its with a timing gun i alreay did that...it looks to be off my alittle bit to the right
Old Sep 5, 2006 | 03:40 PM
ek4__'s Avatar
bump help
civic_turbo_wannabe
Jun 6, 2009 01:40 PM
93accordsleeper
Oct 7, 2008 07:40 PM
1990si
21
Feb 1, 2007 02:54 PM
civicex_88005
16
Jul 8, 2005 06:02 PM
