00 gsr trunk problem
On my wifes 00 gsr the trunk latch stopped working. when you slide the latch to unlock it, you hear the motor whine but the latch wont unlock. Has anyone had this problem before? i cant get into the trunk to look because of a rear strut bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob »</TD></TR><TR><TD CLASS="quote">On my wifes 00 gsr the trunk latch stopped working. when you slide the latch to unlock it, you hear the motor whine but the latch wont unlock. Has anyone had this problem before? i cant get into the trunk to look because of a rear strut bar. </TD></TR></TABLE>
Funny, my 00 GSR is doing the exact same thing. If you rotate the key past the unlock position, it will manually pop the hatch, you just need 2 hands to lift the hatch while you keep the key rotated.
Previously, I've only had that problem when I stuffed too much into the trunk, and the hatch had enough pressure to prevent the wimpy electric motor from opening it.
common problem... my '00 gsr has the same problem. the trunk actuator is bad, just use the key and turn it all the way to the right, should pop the hood like tunern00b said
A trick I use is I don't turn the latch all the way to the left, I slide it until I hear the motor unlatch the hatch. If you do all the way, it gets all stuck and I can't close it anymore.
Yeah its a problem with happens alot with 98-01 tegs. Team integra website has an article that shows the part number u need and how to replace the actuator.Its quite simple to replace.
jefferson1
Jul 18, 2010 11:34 AM
RuskeR
Aug 23, 2005 09:40 AM
Kicker773
Oct 10, 2004 04:42 PM
