ODO Rollback to 000000?
Old Sep 5, 2006 | 12:14 AM
Eyal 951's Avatar
Default ODO Rollback to 000000?
I'm looking to rollback my odo to zero. This is for a 95 Hatch, SI cluster. I know its illegal, and all that BS, so don't bother. I just need to know if there is a faster way then literally rolling it back mile by mile? Its all apart already. If not, I think I'm going to get a dremel on it with a rubber bit on the gear. It will work, but I'd rather a less dangerous for the odo method. Thanks!
I'm swapping in a motor I built with ZERO miles on it, and would like the cluster to reflect this. Call it a novelty, thats what I want.
Old Sep 5, 2006 | 12:22 AM
chrisw85's Avatar
i believe you can roll each digit individualy. Is your car a daily driver?
Old Sep 5, 2006 | 12:27 AM
Eyal 951's Avatar
Default Re: (chrisw85)
yea, its the daily. You can't roll them individually. there are some gears inside the roll on numbers. No idea how to take it apart... I think it needs to be broken to be disassembled. I think I'm stuck manually doing it, but want to see if anyone has anything to say. I know some other clusters you can disingage, but not this one.
Old Sep 5, 2006 | 12:28 AM
Sean @ ESG's Avatar
I believe there was a write up on how to do this somewhere on HT. Try searching, it should come up. From what I remember it is a very delicate process
Old Sep 5, 2006 | 12:29 AM
Eyal 951's Avatar
Default Re: (banzai_ESG)
there are write ups, but they are integra, or about swapping the speedo in clusters. The Integra is different, and much easier. The search yeilded nothing helpful regarding my question.
Old Sep 5, 2006 | 05:26 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Eyal 951)
use two dentist picks. You should be able to pry | | | the bold ones apart and move the not bold one. That's how i've seen it done. It works in Ej/ek clusters so I'd think it would workin yours. You just have to pull it back far enough so the pin in the middle spins freely.
pliskin8
13
Feb 19, 2011 06:36 AM
JDMJUNKIEMONKIE
11
Feb 2, 2010 09:41 PM
Dam itz Lou
12
Nov 9, 2009 10:17 AM
310Integra
Sep 8, 2007 10:54 PM
pdiggitydogg
11
Sep 26, 2004 06:26 PM
