sunroof leaking what to do
the other day it rained really hard and i got in my car and i saw that water was leaking from the sun roof. So i opened the cover thing and a pool of water fell on me. What shold i replace or do to fix this problem. Is there a gasket i could replace or would replacing that rubber ring around the sunroof fix it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF honda EF »</TD></TR><TR><TD CLASS="quote">the other day it rained really hard and i got in my car and i saw that water was leaking from the sun roof. So i opened the cover thing and a pool of water fell on me. What shold i replace or do to fix this problem. Is there a gasket i could replace or would replacing that rubber ring around the sunroof fix it?</TD></TR></TABLE>
I am assuming you have a Civic Si? The OEM sunroof is designed to leak, so replacing seals won't help. Your problem is most likely a clog in one or more of the four sunroof drainage tubes. The drain tubes can usually be cleared with a shot of compressed air.
hbracer93
41
Apr 6, 2022 05:04 AM
FRKWOO
14
Sep 25, 2008 08:47 PM
