oil press gauge install help please
Old Sep 4, 2006 | 10:55 AM
egzo04's Avatar
Default oil press gauge install help please
i have a 90 crx dx, i got this gauge http://www.autometer.com/cat_g...sid=3
it says to drill a hole in the oil pan, id that the only option i have? or can i just find an adapter for the oil pan plug?
Old Sep 4, 2006 | 10:59 AM
theinfamouskonrad's Avatar
Default Re: oil press gauge install help please (egzo04)
Most people just T it in with the oil sender on the back of the block. I like using an oil sandwich adapter. Golden eagle makes one, as well as other companies.
Old Sep 4, 2006 | 11:12 AM
Magick211's Avatar
Default Re: oil press gauge install help please (theinfamouskonrad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theinfamouskonrad &raquo;</TD></TR><TR><TD CLASS="quote">Most people just T it in with the oil sender on the back of the block. I like using an oil sandwich adapter. Golden eagle makes one, as well as other companies.</TD></TR></TABLE>
The oil sandwich adapter goes in between the oil filter, correct? Those things are nice
Old Sep 4, 2006 | 11:13 AM
31flavorscivic's Avatar
bad things have happened to people who run hot oil lines in their car for that reason
find a way to do it electrically.
Old Sep 4, 2006 | 11:57 AM
Default Re: oil press gauge install help please (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">bad things have happened to people who run hot oil lines in their car for that reason
find a way to do it electrically.</TD></TR></TABLE>
That's why you use a stainless line instead of the nylon one provided.
Old Sep 4, 2006 | 02:02 PM
Rejman61's Avatar
I ran a similar autometer on my car for years, like the man said run a tee off of the back of the block and lose the nylon. autometer sells the braided hose for gauge.
Old Sep 4, 2006 | 05:10 PM
egzo04's Avatar
Default Re: oil press gauge install help please (Rejman61)
thanks for the feed back
Old Sep 4, 2006 | 07:40 PM
2slow4stock's Avatar
Do it where the oil pressure sending unit is, you can get a T fitting for it or just unplug the wire from the sensor and put the adaptor on it. USE teflon tape when your threading it in or you will leak.
Old Sep 4, 2006 | 09:14 PM
1990si's Avatar
Default Re: (2slow4stock)
yea i got the same gauge as you. you dont need a t if you dont want your stock oil pressure light. if you do get a t. if not then just unscrew the stock oil light sensor. and they do sell the t fitting at most hardware stores. lol
Bense
19
May 19, 2006 05:44 PM
lude98SH
Jan 30, 2006 03:46 PM
mark_is_gay
15
Jul 13, 2005 12:18 PM
Screamer
May 14, 2003 11:35 AM
SPOON_BeIgHtEeNsEe
Mar 4, 2002 05:24 PM
