Check engine light
Old Sep 4, 2006 | 02:28 AM
ALLmotorTYPES's Avatar
Default Check engine light
I just bought a 02 rsx s and every time i get gas, a day or two later the engine light comes on. and after that i will reset the ecu and it will stay off untill i get gas. I also make sure my gas cap is on all the way. should i be worried?
Old Sep 4, 2006 | 02:30 AM
dc5tegk20's Avatar
Default Re: Check engine light (MyliTTLeDc5)
what kinda of gas are you using?
Old Sep 4, 2006 | 02:31 AM
Default Re: Check engine light (dc5tegk20)
chevron 92 octane
Old Sep 4, 2006 | 02:36 AM
dc5tegk20's Avatar
hmm i dunno man i was gonna say make sure your using premium but seems you got that taken care of good luck hope you find your problem
Old Sep 4, 2006 | 02:38 AM
Miracle's Avatar
Best advice I can give. Go to your AytoZone, Oreilly's or Advance and have them read that code. Your clue as to what the problem is is in that code. That way, you will know where to start troubleshooting.
Old Sep 4, 2006 | 02:39 AM
Default Re: Check engine light (.Red.EM2)
Thanks for the help. I have only owned it for a week and it started the problem.
Old Sep 4, 2006 | 05:22 AM
ballerchild's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 &raquo;</TD></TR><TR><TD CLASS="quote">Best advice I can give. Go to your AytoZone, Oreilly's or Advance and have them read that code. Your clue as to what the problem is is in that code. That way, you will know where to start troubleshooting.</TD></TR></TABLE>
see what code its throwing and let us know so we can give you more input.
Old Sep 4, 2006 | 09:24 AM
Default Re: Check engine light (ballerchild)
ok sounds good. I will go to autozone today.
Old Sep 4, 2006 | 10:41 AM
Ok I just got back from Autozone and heres what it said.
Code P0172 System too rich (Bank 1)
Any Idea's?
Old Sep 4, 2006 | 11:13 AM
Any body?
Old Sep 4, 2006 | 11:18 AM
Miracle's Avatar
That is a misfire code. Which is what is causing it to run rich. Check your ignition system. Plugs and such. As well as timing. That could also allow it to run a tad rich if the timing is off a tad.
Could be a couple other things too, but I'm still researching.
Old Sep 4, 2006 | 06:04 PM
Bumb
Old Sep 5, 2006 | 11:30 AM
Anybody have any more idea's?
Old Sep 6, 2006 | 10:43 PM
mR. Vash's Avatar
Here's some advice: Boost
Old Sep 8, 2006 | 05:28 AM
eff sea's Avatar
Default Re: Check engine light (mR. Vash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mR. Vash &raquo;</TD></TR><TR><TD CLASS="quote">Here's some advice: Boost </TD></TR></TABLE>
That's actually not that bad of an idea, since you're running rich...
Old Sep 8, 2006 | 08:43 AM
a2_DC5's Avatar
nicokpe
Sep 29, 2007 04:50 AM
dasso10
Dec 19, 2006 04:39 AM
ArthurBrazil
10
Oct 8, 2006 02:45 PM
SuPeRITR
Mar 18, 2003 06:02 PM
civicracer1993
Apr 18, 2002 06:57 PM
