Srs light stuck on after integra dash swap. "Searched"
Old Sep 3, 2006 | 10:35 AM
dem0nk1d's Avatar
Default Srs light stuck on after integra dash swap. "Searched"
Well I finally hooked the integra dash in the old hatchback everything came out pretty clean. My question is I had to take the passanger side air bag, for the dash to fit. So it's not hooked up. The steering wheel is hooked up, so it's all plugged in. Do I need to rest the SRS system. But will it still throw the SRS light because the passanger side isn't hooked up? Also I read something about adding a resistor, but they never went into detail. So what should I do? I don't want to unplug the light ot disconnect the plug behind the gauge.
Old Sep 3, 2006 | 10:46 AM
ctr status's Avatar
Default Re: Srs light stuck on after integra dash swap. "Searched" (dem0nk1d)
As long as you have the passenger side airbag out the srs light will be on. Ive heard about something that you can clip into the plug to make the light go off, so you might want to research that.
mad_affliated
Apr 22, 2013 01:45 PM
So FReSh
Oct 9, 2008 12:29 PM
Caveman74
Nov 5, 2006 05:16 PM
turbolag98
Aug 13, 2003 11:22 PM
fire7882
Aug 27, 2002 03:29 PM
