s2000 seats install problem
I got the seats bolted in but then i noticed that there were no seatbelt buckles attached to the seat. What seat belt buckles should i use? LMK....asap...cannot drive unless i have seat belts.
Unbolt your stock one and bolt it on. Actually, the buckles should already be on the rails since you are using the stock seat pan and rails that came with your car. Unless you took spare seats with buckles and swapped everything over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tempsohc »</TD></TR><TR><TD CLASS="quote">I got the seats bolted in but then i noticed that there were no seatbelt buckles attached to the seat. What seat belt buckles should i use? LMK....asap...cannot drive unless i have seat belts.</TD></TR></TABLE>
How did you bolt them in? Because you were supposed to swap the S2000 seat pans with your stock Civic seat pans (with attached buckles) . . .
https://honda-tech.com/zerothread?id=347548&page=1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tempsohc »</TD></TR><TR><TD CLASS="quote">3 bolts matched up</TD></TR></TABLE>
buell22
Jan 26, 2008 12:38 PM
EgSalad
Sep 13, 2006 10:20 AM
civicrr
12
Aug 9, 2002 08:53 PM
