Extracting torqued off bolts
Old Apr 28, 2002 | 10:26 AM
blownsi's Avatar
New User
Default Extracting torqued off bolts
I recieved a head with a torqued off 12mm bolt that holds down the cam cover on a B16. The top end was torqued off leaving the threaded part of the bolt still in the bolt hole of the head. I tried a tap and extracter to get it out but the extractor bit broke off inside the bolt. Anybody got any ideas on how to get this thing out?
Old Apr 28, 2002 | 12:22 PM
JDM_DOHC_SiR's Avatar
New User
Default Re: Extracting torqued off bolts (blownsi)
You might be Fu@k'd Take it to a machine shop...that might be your last hope
good luck
Old Apr 28, 2002 | 12:39 PM
qtiger's Avatar
Uh... if you broke of an extractor bit, most likely it will need to be burned out. Hopefully a machine shop near you will have the necessary equipment.
spidermancivic
Aug 11, 2007 08:17 AM
Yelowfever
Jul 10, 2007 08:06 PM
spidermancivic
Oct 3, 2006 09:41 PM
BoostinEJ1
41
Apr 16, 2006 01:18 PM
SRd240sx
Oct 22, 2002 05:52 AM
