Doing a compression test..some Qs
most people do it 5 revolutions, but until the needle stops moving is fine also it is almost right around that amount of revolutions that the needle does stop moving or will come very close to not moving. As long as you use the same cranking method for all cylinders I think that is more important. I think you will find that after 5-6 revolutions the needle will not increase any more. Just be consistent.
Yeah thats what I do crank until it stops moving on all cylinders, when your doing the test by yourself its hard to determine a revolution.
(No offense to people that are hard of hearing)
I guess....The only thing i can hear is the starter.
But all my compresion numbers are
300 psi in all cylinders. Its probably higher but the tester only goes to 300 psi.
