Doing a compression test..some Qs
Old Apr 28, 2002 | 09:52 AM
Chubz's Avatar
Default Doing a compression test..some Qs
How many times do you crank it over? Ive heard 6 times, but a mechanic told me until the needle stops moving
Old Apr 28, 2002 | 10:11 AM
Chubz's Avatar
Default Re: Doing a compression test..some Qs (RLukas)
anyone
Old Apr 28, 2002 | 10:23 AM
JSIR's Avatar
New User
most people do it 5 revolutions, but until the needle stops moving is fine also it is almost right around that amount of revolutions that the needle does stop moving or will come very close to not moving. As long as you use the same cranking method for all cylinders I think that is more important. I think you will find that after 5-6 revolutions the needle will not increase any more. Just be consistent.
Old Apr 28, 2002 | 10:30 AM
Chubz's Avatar
Default Re: Doing a compression test..some Qs (JSIR)
Yeah thats what I do crank until it stops moving on all cylinders, when your doing the test by yourself its hard to determine a revolution.
Old Apr 28, 2002 | 10:43 AM
rocket_R's Avatar
when i did mine, the first 3 were good but when i did #4 there was a loud knock let it was hitting something. what does this mean?? the car runs fine
Old Apr 28, 2002 | 10:44 AM
C-speed's Avatar
Only if your deaf. (No offense to people that are hard of hearing)
Old Apr 28, 2002 | 10:49 AM
Chubz's Avatar
Default Re: Doing a compression test..some Qs (G3-TEG)
I guess....The only thing i can hear is the starter.
But all my compresion numbers are
300 psi in all cylinders. Its probably higher but the tester only goes to 300 psi.
Old Apr 28, 2002 | 10:50 AM
BrandonClaps's Avatar
New User
300psi, uhh on what kind of engine?
Old Apr 28, 2002 | 10:51 AM
Chubz's Avatar
Default Re: Doing a compression test..some Qs (BrandonClaps)
b18c1 block with CTR pistons w/b16 head
Old Apr 28, 2002 | 10:53 AM
New User
i c, ok
MRturbo
Feb 20, 2008 06:25 PM
obsidianG35
Aug 20, 2003 02:04 PM
RTW DC2R
Jul 21, 2003 08:06 AM
JCracer723
Aug 21, 2002 07:50 PM
Cyber ITR
Feb 12, 2002 03:19 PM
