Kill switch wiring for NHRA legality.
Old Sep 2, 2006 | 03:50 AM
mrchris1979's Avatar
Default Kill switch wiring for NHRA legality.
I have the battery relocated to the trunk and have a kill switch installed on the rear for proper access. I'm just trying to figure out how I can totally shut the car down once the switch is turned off. I know that the alternator needs to be directly connected to the positive battery post but do I connect the alternator wire that goes to the fuse box in the engine bay or do I use the one that is bolted on to the alternator? Also what gauge wire is recommend for this?
Here's a pic of the set-up..kill switch in the key hole.
It then goes to this distribution block. One wire to the fuse box and the other to the starter. Looking at the fuse box, the wire next to the loomed one is for the alternator ( I think ). Do I connect it to the battery or the one that is bolted to the alternator so the car will totally shut down?
Old Sep 2, 2006 | 05:34 AM
d16a6crx's Avatar
I also was thinking about relocating my battery, but need to use the key (hatch release doesnt work)
anyone have pics of the kill switch anywhere else.
also, what kit did you use?
Old Sep 2, 2006 | 05:41 AM
B16CRXT's Avatar
Default Re: (d16a6crx)
you can buy those kill switches at WalMart, I saw them there the other day. You dont have to do the kill switch if you are justy moving the battery to the back for the hell of it, but if you are in professional racing, you have to.
Old Sep 2, 2006 | 10:42 PM
mahatma's Avatar
Default Re: (B16CRXT)
i don't understand your question
to me it looks like it's all done properly
looks fast too
Old Sep 2, 2006 | 11:15 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">you can buy those kill switches at WalMart, I saw them there the other day. You dont have to do the kill switch if you are justy moving the battery to the back for the hell of it, but if you are in professional racing, you have to.</TD></TR></TABLE>
Nope, I took my car to sears point wed night drags... got turned away for my battery setup. I need a external kill
Old Sep 3, 2006 | 01:30 AM
Default Re: (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">i don't understand your question
looks fast too </TD></TR></TABLE>
It's wired up properly to shut down battery power and the MSD ignition box but the alternator still keeps the car running. I thought for sure the way I had it wired up will totally kill the car but I guess the alternator needs to be cut off as well. Just not sure how to do this.
91-lsvtecsi
Mar 15, 2012 04:14 PM
JBLAZE622
Jun 27, 2008 11:55 AM
mrchris1979
Apr 14, 2008 11:55 AM
ScottEK
Mar 29, 2007 09:52 AM
redboost10
Aug 11, 2006 07:31 PM
