gsr del sol swap issues!!!! PLEASE HELP!!!
Old Sep 1, 2006 | 06:34 PM
Midori so sickkkkk's Avatar
Default gsr del sol swap issues!!!! PLEASE HELP!!!
ok so just swapped a jdm b18c1 into my del sol... car runs real strong chirps 3rd surprizingly enough and holds its own with some pretty quick cars.... Im coming from a 400hp evo 8 and was pretty impressed... now heres the problems... launch bogs real bad not sure why its almost like the car turns off for a split second.. like boost cut. second, ever since motor swap tach jumps around crazy don't know if it has anything to do with vss or not.. but any kinid of input on this would be great.
mods are 2.5" cat back exhaust, aem short ram intake, mugen chipped ecu.
and any suggestions if i should go spray or turbo??
Old Sep 1, 2006 | 06:39 PM
VegaS10's Avatar
Tach bounce is usually a sign of a faulty dizzy.
Old Sep 1, 2006 | 07:55 PM
Default Re: (VegaS10)
bump
Old Sep 1, 2006 | 08:27 PM
jdeemseerx's Avatar
the problem your having at launch could be a number of things, i had that problem wit my b16 crx and it turned out to be a loose ground cable on the tranny.. so check out your grounds, and the bouncing tach could either be your dizzy crappin out or your IAC..
Nickerr101
Oct 15, 2014 12:22 AM
1slowcrx
Oct 26, 2008 09:28 AM
honda06si
Jun 16, 2005 09:52 PM
LbcJiGGa
Mar 18, 2003 06:14 AM
