valves bent? vid included
Old Sep 1, 2006 | 04:38 PM
JSpekBB4's Avatar
Default valves bent? vid included
heres a vid of the sound my cars making, someone said it sounds like my timing is off another one said my timing belt is broke.... and than someone said that if it is my timing belt, than my valves are def bent.... if I put a new timing belt and reset the timing should it still start even if the valves are bent?... and whats the chances of my valves not being bent? hit me back please... heres the vid
http://media.putfile.com/Prelude-Starting-Problem
Old Sep 1, 2006 | 07:13 PM
Desir Performance's Avatar
Default Re: valves bent? vid included (JSpekBB4)
Did you check your timing? If you bent valves the car would run rough and probably not start if you bent more then one, the only real way to tell is to do a leak down test.
Old Sep 1, 2006 | 07:21 PM
JSpekBB4's Avatar
Default Re: valves bent? vid included (Desir Performance)
well the car never turned on... I drove it, parked it, it snowed for 4 days tried to start it and its been doing what it's doing in the vid ever since... people told me what prob happen is the timing belt is broke (which I just took the valve cover off and it is broken... looks cut rather than torn... but anyways they siad that since the engine was prob still frozen, and when I tried to crank it, one of the gears moved and not the other which caused the timing belt to break... which I guess would mean my valves should be fine? right? I bought a new timing belt today just incase it was broken or just to replace it... whats the chances of the valves being bent? since the car didn't star or turn over when I cranked it?
Old Sep 1, 2006 | 10:15 PM
qfast817's Avatar
well how many miles are on it? ive ripped off 16 teeth on a timming blet and it did the same thing
Old Sep 2, 2006 | 06:36 AM
Heretic:Si's Avatar
i'm not sure if i understand you fully, but if one cam not moving is why your belt broke then something else is wrong, bent valves or broken cam. your car won't turn over normally without a timing belt since the only thing moving is your crank. when it comes to broken timing belts either you're fuct w/ bent valves or you're fine and just need a new belt.
Old Sep 2, 2006 | 07:15 AM
TransformedBG's Avatar
Default Re: valves bent? vid included (Heretic:Si)
Well i think ide rather have bent vavles than broken ones lol. But your probably going to have to pull the head to make sure. So what exzactly happened when you drove it home?
Old Sep 2, 2006 | 08:18 AM
JSpekBB4's Avatar
Default Re: valves bent? vid included (TransformedBG)
nothing thats the thing, it drove perfect, never drove like it did that night before... than when I parked it locked the car up went inside didn't start it for like 4 or 5 days cuz it snowed and can't really drive a slammed prelude in the snow.... so it was still really cold outside, but I went outside tried to start it, and it just did what the vid shows
Old Sep 2, 2006 | 09:56 PM
I wonder if you got the belt wet *if it was dry rotting(sp?)* and it froze causing the water to expand and snap the belt... could be a possiblity.
Old Sep 3, 2006 | 08:26 AM
alterdcreations's Avatar
how cold is it? if you dont have a proper mixture in you coolant system your coolant could have frozen. freexing the water pump. i would wait untill it goes abouve freezing and try again. if it starts then you need to change your coolant/water mixture. if not then check the battery and make sure it has water in it and it is at proper level. if all of these things are with out a problem then i would pull the spark plugs and try to crank it woth out them in. if it cranks then make sure you dont have any water or ice in the cylinder system. if you drove a slamed prelude in the snow with a cold air intake then you might have sucked up some water into your engine or froze your air filter and the car cannot suck up air becaust the cold air system is blocked. check these things first before you start tearing down your engine. i sounds like the engine is sufficating and maybe you cannot get any air in. if all of these things are fine then check your timing. process of elimination
Old Sep 3, 2006 | 10:53 AM
JSpekBB4's Avatar
Default Re: valves bent? vid included (alterdcreations)
no I didn't drive in the snow, I won't drive it in the snow.... the timing belt is broke, took the vc off and it's snapped, so gonna replace it and see what it does..... any idea how to get the crank pulley bolt off with a out a air rachet?
Old Sep 3, 2006 | 12:32 PM
projectTeG's Avatar
sounds like your cam timing is out. i had this problem on a ls/vtec i help a fried complete(exhasut cam was 180 out)
Old Sep 5, 2006 | 07:30 AM
Default Re: (projectTeG)
Lol, with out an air wratchet? umm a breaker bar and about a 12 ft extention lol.
Old Sep 5, 2006 | 01:31 PM
BuddhaSiR's Avatar
Default Re: (TransformedBG)
you'll need this, Moroso crank pulley holding tool. Works on B-series, H-series, and F-series motors
I misplaced mine. Can someone buy me a new one? Thanks
Old Sep 5, 2006 | 08:02 PM
JSpekBB4's Avatar
I stuck a screw driver thru the slot on top of my engine by the dizzy, and used 2 10in extentions and a 2 foot breaker bar and it came right off, car runs again, no ticking no nothing runs smooth! thanks for thelp everyone
lsvtec2000
Jan 3, 2008 07:05 AM
JSpekBB4
Sep 1, 2006 08:18 PM
06Xrunner
Nov 25, 2003 09:18 AM
AK94GSR
May 10, 2002 09:39 AM
Redline130
Aug 13, 2001 10:09 PM
